Tractor Talk Discussion Forum
Winch on a tractor bad idea?
ray
03-22-2004 12:30:43
Thinking about ways to speed up loading logs onto a sawmill -- bandmill.
I have a couple of winches not being used. Would it be a bad idea to mount a winch on a front loader -- that is inside the bucket or on top of it?
The way I envision things working is I'd park /anchor the tractor on one side of the mill log pile on the other side. Winch the log up ramps onto the mill. I use the loader with forks to load the mill now.For me its a time eater when working alone. The winch would be positioned so I could still use the forks to move milled timbers.
I'll chock the wheels on the tractor etc...tractor weight 7,000lbs or so -- Don't want to see tractor parts flying off --- logs are round de-limbed and on runners, not rolled on ground.
RJ-Az
03-22-2004 20:28:01
 Re: Winch on a tractor bad idea? in reply to ray, 03-22-2004 12:30:43
Most one man saw mills I have seen are a tinkerers heaven. I have seen wore contraptions and apparatus'for moving logs, sawn lumber,sawdust and slabs than you can imagine. So knock yerself out and engineer whatever you can.
Mark
03-22-2004 13:15:23
It will probably take more time.By the time you start the tractor,mess around with getting the cables right,pull them up on the log bed,unhook the cables and get another log,you could have put 6 logs up with the loader.It would be easier to build a larger table, put long forks on the tractor and sit 8-10 logs up.Use your winch on the table to pull the logs to you.
