Tractor Talk Discussion Forum
460D stuck in reverse!
Gary in MOzarks
03-21-2004 10:21:06
I was spreading gravel this morning with our 460D on a slight incline. When I tried to put it in reverse it didn't want to move. I keep fooling with it and eventually got it into reverse but letting out the clutch killed the engine. I discoverd that the transmission is in reverse when the shifter is in netural and putting it in any other gear kills the engine. Help What did I do, and what do I do now? Thanks
Gary in MOzarks
03-22-2004 13:45:25
 Re: 460D stuck in reverse! in reply to Gary in MOzarks , 03-21-2004 10:21:06
Just wanted to thank you all for the imput, I did what you said and you were right! THanks G
tinman
03-21-2004 19:01:13
Clean the dirt off the platform and remove the shift tower. Use a larage screwdriver to move the rail(s) into neutral. It is usually caused by the shifting lever worn out at the bottom or clutch and TA out of adjustment. Put your hand on shift lever palm down when shifting. Eliminates the natural curve from lifting up on the shifting lever.
MAGNUMBOY
03-21-2004 18:28:38
I have a farmall 300 that had the same problem.Ithe end of the gear stick that moves the selectors inside was worn. I welded up the end to fit the slot in the selectors better and it hasn't done it since. Hope this helps.
old
03-21-2004 11:29:20
After you get that problem fixed you also may need to adjust the clutch/TA if they are out of adjustment some times it wil make it hard to get out of gears
Gary in MOzarks
03-21-2004 12:20:05
 Re: Re: 460D stuck in reverse! in reply to old, 03-21-2004 11:29:20
Thanks folks I think i understand the problem now. Its probably partially my fault as I probably should have adjusted the clutch before this. Its been all the way to the bottom before it disengauges and I have put off adjusting it. Thanks again for all your help Gary
old
03-21-2004 16:48:05
 Re: Re: Re: 460D stuck in reverse! in reply to Gary in MOzarks , 03-21-2004 12:20:05
Good way for doing in your TA, By the way Gray what part of the MO ozarks are you in I'm at the lake of
Gary in MOzarks
03-21-2004 17:59:38
 Re: Re: Re: Re: 460D stuck in reverse! in reply to old, 03-21-2004 16:48:05
Vienna, Maries Co just the other side of Iberia. Thanks The TA was the one thing that worked on it LOL
old
03-21-2004 19:10:04
 Re: Re: Re: Re: Re: 460D stuck in reverse! in reply to Gary in MOzarks , 03-21-2004 17:59:38
Well if the TA works I'd adjust the clutch/TA before it goes out. I'm 7 miles south of Camdenton, I have a 450 that is nice and another 450 that I'm fixing up for a friend, thats how I know about gears being stuck and the TA thing
mikeinmo
03-21-2004 19:50:01
 Re: Re: Re: Re: Re: Re: 460D stuck in reverse! in reply to old, 03-21-2004 19:10:04
Wouldn't have wanted to be 7 miles south of Camdenton first week of May last year. Glad you are OK. I'm half way between you guys at the Maries/Miller county line between Iberia and Vienna. I work at the Lake. Good to hear from my IH "neighbors".
old
03-21-2004 21:58:32
 Re: Re: Re: Re: Re: Re: Re: 460D stuck in reverse! in reply to mikeinmo, 03-21-2004 19:50:01
I'm still fixing thing up because of that storm, it fliped my hay barn and wiped out about half the trees on the place, but it did miss the real important stuff
Gary in MOzarks
03-21-2004 20:42:50
Heck, We need to start a reunion! LOL I've got a IH 2500 constructall backhoe with a cracked block that I am trying to fix (looking for a doaner engine c153 or anything that will bolt up) and two TD-9 dozers that I am trying to make one out of, and I am way over my head. Anyone want a left over dozer? [email protected]
Leland
03-31-2006 18:43:07
 Re: Okay, It's Time in reply to Allan In NE, 03-31-2006 06:55:50
Allan I have seen farms where the new guy taking over had to bring in a road grader to clean up the fence rows since the last guy had always thrown it out for the last 25 years .
old
03-21-2004 22:02:45
 Re: Re: Re: Re: Re: Re: Re: Re: 460D stuck in reve in reply to Gary in MOzarks , 03-21-2004 20:42:50
I have a good H Farmall engine that I don't need, I also have an F12 that I'm working on a 1935 JD-B that I just got runnin. Check out my web site
RAB
03-21-2004 10:41:15
You somehow managed to get two gears at once. Try removing gearstick, shifting selector gates into their neutral positions, replace gear stick in the neutral position and try again. You may find one of them needs some attention if its not in neutral when all are in correct position, and you may need some attention later to repair/adjust the selector mechanism.
Regards, RAB
