Tractor Talk Discussion Forum
Ford 600
Stan Jones
03-21-2004 06:54:05
When I push in the clutch pedal the clutch does not disengage,if I jam it in gear it takes off,if I pound on the brake it breaks free and everything is fine,till its parked for awhile,and now pounding on the brake isnt working anymore,,any suggestions.
Thank You
JDknut
03-22-2004 03:41:23
 Re: Ford 600 in reply to Stan Jones, 03-21-2004 06:54:05
Sounds like your clutch is hosed. The same thing happened to my Deere last year and I ended up putting a new clutch in it.
RWK in WI
03-21-2004 17:29:28
It is a good idea to "block" or tie the clutch down when you park it . Working it with the clutch pedal held down often breaks it loose. Slipping the clutch tends to polish the disk and make it work better.
RickB
03-21-2004 16:22:14
Time to split it and replace the disc, release and pilot bearings, and perhaps the pressure plate.
