Tractor Talk Discussion Forum
Ford 9n - 6 volt generator spins when key is ON
john
03-17-2004 20:09:46
The mounting bracket on my 6 volt generator broke, so I purchased an aftermarket replacement. It is only a single wire so I didn't think it should be a a difficult swap.
Now when I turn the key "ON" the generatator spins even though the tractor is not running. Is it backfeeding somehow???
JT
03-17-2004 23:02:03
 Re: Ford 9n - 6 volt generator spins when key is O in reply to john, 03-17-2004 20:09:46
You need a cut out.
Generators will motor when electricity is applied to them. The old cutouts were a coil and point set up I think someone is making solid state units now. Just a diode adequite of handling the ampreage.
Check the parts section of this site or the store where you got the generator.
HTH
JT
Ray
03-18-2004 08:15:50
 Re: Re: Ford 9n - 6 volt generator spins when key in reply to JT, 03-17-2004 23:02:03
I had this happen to me with a 12v alternator when a contact stuck in a new voltage regulator. Once I freed the contact it quit misbehaving.
