Tractor Talk Discussion Forum
HELP please
kyle
03-17-2004 18:19:53
every time i go to start my tracter it blows gas out the carbrater before it starts. does anybody know what's going on?
bill
03-18-2004 15:34:32
 Re: HELP please in reply to kyle, 03-17-2004 18:19:53
check the timeing on your engine dis cap point gap good place to start
49 Cubber!
03-18-2004 14:30:19
Maybe if someone knew what kind of tractor youre working on,they can help diagnose your problem.Many different tractors with many different carbs and can have many different problems.
John *.?-!.* cub owner
03-18-2004 06:43:59
Many tractors have drain holes in the carb close to the breather pipe to let any excess gas drain out from flooding. It sounds as if you may be over choking it. Try pulling the choke out and turning it over a couple times, and then ease the choke back in about half way.
marlowe
03-17-2004 19:06:31
first how can you see this?all tractors have a air tube or air cleaner on them so the system is sealed to dirt and if it's sealed you could not see this. but if you can then you are missing some parts and this is more to worry about then a little spray back at this time. you are sucking in all kind of dirt that will rune your engine VERY fast or to might be runed allreedy
twopop
03-17-2004 18:32:24
my first thought is you have a leaking intake valve or a cracked distributor cap
Jerry
03-18-2004 04:43:10
 Re: Re: HELP please in reply to twopop, 03-17-2004 18:32:24
A restriction in the muffler can also cause this. Usually can't get good rpm if you have a restriction.
