Tractor Talk Discussion Forum
185 cub lo boy
Chad Wilcox
03-16-2004 16:36:10
I have a 185 cub lo boy. It has a bunch of blow by out of the breather. It misses at full throttle and runs good at mid throttle. It has a knock that comes and goes. This is my first lo boy. Any information would be appreciated.
RAB
03-17-2004 13:45:43
 Re: 185 cub lo boy in reply to Chad Wilcox, 03-16-2004 16:36:10
Chad,
Presuming it's a gas engine. Has it been tuned up properly? Could be timing, carburation, incorrect plug grade or something more serious causing the problem. Sounds like it may be in need of a top end overhaul - decarbonisation at minimum, may need new rings or even more. Could the knock be detonation (red hot carbon in the engine)?
Start on the easy checks - does it burn oil, timing, colour of plug insulator, view thru plug hole etc.If you have just bought it I would suspect that it's previous history has not been fully disclosed and may not be too good reading....
Regards, RAB
Bigdog
03-16-2004 17:06:41
Sounds like it's time for an engine rebuild. Check your compression and valve clearances.
CHAD WILCOX
03-20-2004 20:04:09
 Re: Re: 185 cub lo boy in reply to Bigdog, 03-16-2004 17:06:41
I TORE THE ENGINE APART AND FOUND THE BEARINGS
WERE WORE BUT DID NOT TARE THE CRANK UP THE CYLINDER WALLS WERE REALLY SMOOTH BUT #2AND #3 HAD ALOT OF CARBON BUILD UP SO I TOOK AND HAD THE CYLINDERS CHECKED BY MY FRIEND WHO DOES STOCK CAR ENGINES FOUND CYLINDERS JUST NEED A QUICK GLAZE REMOVAL BUT RINGS ON BOTH CYLINDERS WERE LINED UP WHICH WOULD PROBABLY CAUSE A PROBLEM SO I WILL PUT RINGS AND ALL NEW VALVES AND SPRINGS IN IT AND ALL NEW LOWER END AND HAVE CRANK POLISHED WOULD THIS BE THE RIGHT WAT TO DO THE MOTOR OR SHOULD I GO FARTHER I APPRECIATE THE REPLIES IT HIT PRETTY WELL ON THE HEAD
I WOULD APPRECIATE THE ROD AND HEAD TORQUE SPECS
I WILL UPDATE YOU ON HOW IT TURNS OUT AFTER REBUILD
THANKS AGAIN
