Tractor Talk Discussion Forum
ned help cub hydraulics
larry h
03-12-2004 15:03:24
bought a cub with belly mower hyd worked fine hauled tractor 40 miles now they will not work at all checked oil and all levers can you tell me what to look for to fix it
John *.?-!.* cub owner
03-12-2004 18:50:40
 Re: ned help cub hydraulics in reply to larry h , 03-12-2004 15:03:24
Listen for the pump making any sound, as BD said. If it is quiet, and you don't hear the engine load when you move the lever, the nut that holds the drive gear on the pump may have come off. If so it probably is in the oil pan somewhere.
john
03-12-2004 18:40:39
If you drove it up ramps did the pump lose its prime when it was uphill. Just a thought.
Bigdog
03-12-2004 16:07:20
Can you hear the normal whine of the hydraulic pump when the tractor is running?
