Tractor Talk Discussion Forum
Farmall 504
Tom Dennis
03-08-2004 14:21:59
I recently bought a Farmall 504 gas and it has a 6 cylinder engine, live PTO, T/A, and a 2 pt. hitch. I have been checking on the internet for information on it but can find only 4 cylinder models. Did Farmall make a 504 with a 6 cyl. engine or did someone swap it? The emblem on the grill says 504.
Tom Dennis
03-09-2004 06:58:28
 Re: Farmall 504 in reply to Tom Dennis, 03-08-2004 14:21:59
Thanks alot guys, I will start looking for casting numbers to see what hybred I got. Does the 504 and 606 share the same chassis? Any more help you can lend will be appriciated.
Bob
03-08-2004 18:43:56
On same topic I have wondered why IH didn't make a 606 Farmall. My 504 gas does ok but some more juice would be nice sometimes. Think 236 out of 460 will fit?
Jimmy King
03-09-2004 03:45:03
 Re: Re: Farmall 504 in reply to Bob, 03-08-2004 18:43:56
IH did make a 606 farmall I worked at the local IHC dealer for a week in the 60's and they had a 606 Farmall D on the lot.
Joe Evans
03-08-2004 15:13:46
504s were produced with the C-152 4 cylinder motors. Someone inserted a 6-cyl in yours. I'll bet that was a neat trick. However, verify if your 504 is really a 504. Check the S/Ns and casting codes. Perhaps someone swapped some sheet metal from a 504 and put it on a larger tractor. Look for the casting code on the engine block as to what it may be. My guess is a C-221.
Check below for our 504 page and see if your machine matches ours.
tinman
03-08-2004 20:44:12
 Re: Re: Farmall 504 in reply to Joe Evans, 03-08-2004 15:13:46
Liked the story about your dad. Makes me think about the sounds and smell of our 560D.
Hayman
03-08-2004 19:26:25
Just favoritized your great site,Joe.Thanks for sharing.
49 Cubber!
03-08-2004 16:27:18
The section on your Dad brought back alot of memories with my Dad,and a few tears as well!Thanks,I had almost forgot how much I miss him!
Joe Evans
03-08-2004 19:20:16
 Re: Re: Re: Farmall 504 in reply to 49 Cubber!, 03-08-2004 16:27:18
Thank you for the compliment. Dads are special creatures. Am glad I'm one.
Wardner
03-08-2004 16:05:13
The 04 in 504 indicates four cylinders. You either have a 606 (only made as a IH utility model) or a 504 (made as row crop or ulitity) with the 460 or 606 engine swapped in. Although I have not done it, I believe the six cylinder will fit in nicely. There is alot of wasted space in a 504 between the water pump and radiator. The two tractors models share nearly everything but the engine.
