Tractor Talk Discussion Forum
diesel fuel in base
steve
03-06-2004 17:53:40
My uncle is restoring a very old diesel backhoe.He install a remanufactured engine.The engine seems to run o.k.,but after a couple hours the base of the engine fills with diesel.Does anyone know the likely causes?
JMS/MN
03-06-2004 23:06:07
 Re: diesel fuel in base in reply to steve, 03-06-2004 17:53:40
If the injector pump is like a Bosch, with small pistons, the fuel could be leaking past the pistons and into the diesel engine crankcase. Do not run the engine this way- you can lose the engine with the diluted oil.
Bob
03-06-2004 19:22:04
What make is the tractor?
The typical causes for fuel in the crankcase are either a bad shaft seal in in the injection pump, or a bad (leaking) fuel lift pump. There are another possibility, or two.
Knowing the make and model would perhaps enable a more specific reply.
steve
03-08-2004 15:53:02
 Re: Re: diesel fuel in base in reply to Bob, 03-06-2004 19:22:04
I believe it is an old parson backhoe,very heavy machine.Not sure of motor type.
