Tractor Talk Discussion Forum
Power steering problems
dan
03-06-2004 10:28:10
The power steering on my '79 SAME Buffalo 130 will not turn left or right when the tractor is stopped, once the tractors wheels start moving the power steering works perfect. I Replaced the power steering ram seals but no improvement seen.
Any Idea's on what's wrong?
How do I isolate the problem?
Thanks
Patrol
03-10-2004 13:04:54
 Re: Power steering problems in reply to dan, 03-06-2004 10:28:10
Some, but main components in the steering system may leak.
- Gear or axial piston type steering pump
- Pressure regulating valve of system
- By-pass valve of system
- Steering cylinder piston "O" or back-up ring
Not enough power in steering cylinders to overcome the resistance of tractor front weight on the wheels.
Comes it up on any ground surfaces?
You will win!
Patrol
david val
03-06-2004 13:33:37
probably a pressure problem. is there any difference at full rpm? if there is, steering pump is probably worn, if there isn't, pressure regulating valve probably needs repair/adjustment.
david
twopop
03-06-2004 10:59:48
if it has a seperate power steering pump,the pump is bad or the pressure bypass valve is leaking or stuck open
