Tractor Talk Discussion Forum
720 STARTING
JOE K
03-05-2004 11:13:40
HAVE A 720 GAS. WILL START EASY WHEN PULLING IT 6-8 FEET. WILL NOT START WHEN USING STARTER.
NEW PLUGS,ELECTRONIC IGNITION,STARTER SWITCH,
WIRES,ETC. HAVE GOOD SPARK AT THE SPARK PLUGS. ANYONE HEARD OF USING A RESISTOR? IF SO WHERE DO I INSTALL IT? THANKS FOR YOUR INPUT.
RAB
03-05-2004 14:47:43
 Re: 720 STARTING in reply to JOE K, 03-05-2004 11:13:40
Do you have a good spark (at a spare plug) when cranking with the starter? If so you may have a leak on the inlet somewhere. Do the plugs get wetted when choked? If so are you still getting a spark at the right place under these conditionsRegards, RAB
buickanddeere
03-05-2004 13:27:16
Is the starting by-pass circuit intact and working. It routes 12V via a starter mounted switch straight to the coil only when cranking. Won't start very well if dropping voltage through the ballast during starting when sytem voltage is already dragged down by the starter.
