Tractor Talk Discussion Forum
Ferguson hyd. in-op after a draft spring adjustme
Rick Hawk
03-05-2004 06:02:34
After a pin and weld repair on the draft piviot bracket. I have on operation of the hydrloics.
Any HELP. RICK
Crem
03-05-2004 22:08:20
 Re: Ferguson hyd. in-op after a draft spring adju in reply to Rick Hawk, 03-05-2004 06:02:34
I don't know which Ferguson that you are referring to, but if it is a TO-20 or 30 I can tell what happened to mine when I tried to adjust the draft spring. The adjusting threads were rusted so that it would not turn. I tried to force it and I snapped off a small stem on the control valve at the bottom of the pump. The fork assembly moved too far because of my twisting effort and snapped the stem which is about 1/16" in diameter. If this is the problem, you have to remove the pump. Possibly it could be welded. I had an extra pump that I installed.
