Tractor Talk Discussion Forum
What is the purpose of paint reducer?
R Wyler
03-03-2004 12:51:25
I got a quart of PPG Flambeau Red today and they sold a quart of reducer with it. I am going to be brush painting a plow with this. Is it like thinner? It says one part paint an a half part reducer this might sound stupid but does that mean use half as much reducer as paint and mix them? Like 1 quart would take a half quart of reducer? I know some of you guys are experienced with this and I need advice. Thanks guys for any help e-mail me if you preffer. R Wyler
Vern-MI
03-04-2004 01:23:26
 Re: What is the purpose of paint reducer? in reply to R Wyler, 03-03-2004 12:51:25
It is similar to a thinner but different in that it has an operating temperature range. You buy the reducer for the temperature that you will be painting at. It controls the drying time and thereby allows the paint to level and become smooth without sags and runs. Some experimentation is required.
R Wyler
03-04-2004 06:16:21
 Re: Re: What is the purpose of paint reducer? in reply to Vern-MI, 03-04-2004 01:23:26
Thanks I didn't know that it was that touchy. I'll have to try it without and then if I need it I'll start with a little and keep adding until it is right. R Wyler
Alberta Mike
03-03-2004 16:31:26
Do a bit of experimenting first to see how it brushes on. Often, automotive-type paint (which I assume your paint is) isn't really made to be brushed on like machinery enamel, etc. You might find it difficult to lay on a nice smooth layer of paint without brush marks and blemishes.
R Wyler
03-03-2004 17:46:40
 Re: Re: What is the purpose of paint reducer? in reply to Alberta Mike, 03-03-2004 16:31:26
Yes I am going to see how it goes at first without thinning it down. I doubt it really needs thinning. R Wyler
Bguy
03-03-2004 13:18:14
I'm no expert but if you are going to paint with a brush then you don't need to use thinner or reducer. Reducer is used to reduce the thickness of paint so you can spray it on thru a gun. Wheb I touch up using JD paint I don't reduce it but I do use the hardner. If I'm off base here I'm sure one of the experts will jump in.
R Wyler
03-03-2004 15:16:43
 Re: Re: What is the purpose of paint reducer? in reply to Bguy, 03-03-2004 13:18:14
Ok I will use my own judgment when I look at it to see how thick it is. I suppose I should use hardner but it should do well like it is. R Wyler
old
03-03-2004 13:03:53
Its used to be able to spray paint it on something so yes its like a thinner
R Wyler
03-03-2004 15:14:40
 Re: Re: What is the purpose of paint reducer? in reply to old, 03-03-2004 13:03:53
Ok thanks I wondered about that. R Wyler
pg
03-07-2004 03:29:15
 Re: Re: Re: What is the purpose of paint reducer? in reply to R Wyler, 03-03-2004 15:14:40
i paint with ppg on my tractors. make sure to put a primer on first. ppg is a uraethane. it wont stick to bare metal very long. since your going to brush it on ,[expensive paint for a brush], make sure to use a hardner. it will take weeks for it to dry without it, if ever. pg
R Wyler
03-08-2004 05:31:39
 Re: Re: Re: Re: What is the purpose of paint reduc in reply to pg, 03-07-2004 03:29:15
Thanks for the info. WHat kind of hardner should I buy?
