Tractor Talk Discussion Forum
timing marks on a John Deere 820
Brian Frank
03-02-2004 17:05:56
Can somebody please help me on how to locate the engine timing marks on a John Deere three clyinder 820. Thank you for your help!
david val
03-03-2004 04:19:16
 Re: timing marks on a John Deere 820 in reply to Brian Frank, 03-02-2004 17:05:56
there is a timing mark (deep scrath) on the camshaft gear and one or several marks on the injection pump gear, if there are several marks they are acompanied with a number representing the number of cylinders. timing is done by putting engine at tdc with the timing pin in its cavity in the flywheel, then pointing the timing marks to the center of the crankshaft by using jd special tool or a string, and then installing the idler gear.
david
