Tractor Talk Discussion Forum
oil burner
Yo
03-01-2004 06:08:28
I have an IH 301 gas engine that runs OK but burns quite a bit of oil and a ridiculous amount of gas. It has a factory set carb. Any thoughts on what I could do to alleviate these problems? Thanks in advance.
mj
03-02-2004 10:38:55
 Re: oil burner in reply to Yo, 03-01-2004 06:08:28
What Ben said AND - you might do the tune-up followed by a can of 'Restore' and see if that slows down the oil usage.
Ben in KY
03-02-2004 08:25:59
I would rebuild the carb. Replace the plugs, points,etc and maybe the wires, check timing/advance, etc.
On the oil burning... a rebuild of the engine would probably be the only way to fix that problem. Or you could just live with it and maybe just put non foulers on the plugs. Is the crankcase breather clear or plugged up ?
This is of course assuming you want to keep the tractor.
RAB
03-01-2004 08:20:43
Stopping it will suffice.
