Tractor Talk Discussion Forum
IH 1086 Tractor - Idle and Oil leak
George DaBai
02-26-2004 20:34:22
Help to a new amature tractor owner. I have recently bought an IH 1086 at an auction. There was one apparent problem with it then. It needed ether to get it started. Being ignorant I attributed that to the weather. Once it started the injection pump will not idle. It will not recover from idle. It used 2-bottles of ether and a jump to get it to stay running with high idle. Once I got it home, after letting it run for two hours, to charge the batteries, I noticed an oil leak. A friend told me that it is comming out of "Blow by tube."
Any suggestions or recommendations. Thank you and may the Lord Richly Bless you.
RAS
02-27-2004 09:04:09
 Re: IH 1086 Tractor - Idle and Oil leak in reply to George DaBai, 02-26-2004 20:34:22
George just a few questions. When you start your tractor and go to high idle & drop it back to low idle is then when it dies and is hard to start. If so it is your fuel injection pump. Remove it and have it rebuild or you can get a Re-man from your Case/IH dealer. If you let it run for two hours and you have some oil comming out of the blow by tube I would not get to worried.
dhermesc
02-27-2004 13:31:17
 Re: Re: IH 1086 Tractor - Idle and Oil leak in reply to RAS, 02-27-2004 09:04:09
Once its rebuilt your starting problems might go away.
JW
02-27-2004 05:31:46
Sounds like you may be in need of a complete overhaul.
RAB
02-26-2004 22:40:31
It sounds like you may have made an expensive purchase, unless, of course, if the price was right!
Regards, RAB
