Tractor Talk Discussion Forum
seperating a farmall for clutch work
Denver Brown
02-23-2004 16:03:37
has any body seperated a farmall super a for clutch work could you give me some pointers. or ideas as to the best way of doing this
Hugh MacKay
02-24-2004 03:05:15
 Re: seperating a farmall for clutch work in reply to Denver Brown, 02-23-2004 16:03:37
Denver: The key to this is having which ever half you are going to move secured so one man can move it, I use a hardwood pallet under front end. First you must install blocking or wedges so front axle is rigid with engine. Use 6x6 and 2x6 blocking and block under front axle and at rear on engine, so entire front end is on pallet. Tie it down to the pallet with ratchet straps. Then use a pallet jack for moving. For the back of tractor all you need is brakes on, chaulk rear wheels and a bottle jack under clutch housing.
I have used this systen on tractors from Super A to 1066. I have even had sevreal components of big tractors on several pallet at once. Chloride filled larger tires with center hub of a large row crop, Put pallet under it strap it to pallet in upright position, move it anywhere you have smooth concrete.
JMS/MN
02-23-2004 21:15:41
Make a splitting stand to hold the front of any tractor- especially a narrow front. Support the rear half with a jack on wheels and roll it away. Then you can tell your spouse and kids how great the system worked- instead of them viewing you in the coffin.
DaveWis
02-24-2004 02:18:06
 Re: Re: seperating a farmall for clutch work in reply to JMS/MN, 02-23-2004 21:15:41
Just wondering why that would be safer than rolling the front, IF the components are properly supported with either method?
john d
02-23-2004 19:16:14
You can crib up under either end and move the other. A hoist will work well to move the front, a pallet jack will move the rear. Make sure everything is solid, and don't let the front of it rock sideways! Remember, if it CAN move, it WILL when you start tugging on parts!
Paul Janke
02-23-2004 17:52:05
I would guess the offset design warrants paying close attention to balance, especially the front half.
Red Dave
02-23-2004 16:23:46
I do A's & B's the same way as Dave says below, block up the rear end and pick the front off with an engine hoist. Not a hard job usually.
Dave_Id
02-23-2004 16:18:57
Check the archives for pointers. Many posts on splitting the tractors.. They are very easy to work on and split.. I usually block up the back end and move the front with a cherry picker, I know other guys that block up the engine and move the rear. Be sure you replace the pilot bushing while you have it apart, it's only a $7 item.
tractorhead
02-24-2004 05:45:03
 Re: Re: seperating a farmall for clutch work in reply to Dave_Id, 02-23-2004 16:18:57
I never did split a tractor, but I was told once to use threaded rods to hold the tractor together,but seprated enough to work on it. Is this a workable idea? just wondering,,, in case someday....thanks jimmy
Rusty Jones/ The Mower Ma
02-24-2004 06:06:59
 Re: Re: Re: seperating a farmall for clutch work in reply to tractorhead, 02-24-2004 05:45:03
Those threaded rods will twist all at the same time, and if the separated half isn't stabilised by something, it will twist and maybe ketch yer hand/s or fingers, or fall on yer foot, at which point you'll be laying there, wondering why ya didn't pay somebody to do the job! You have to have big equipment for that job, not a little bottle jack or scissors jack, and definitely not threaded, mild steel, rods! RJ
