Tractor Talk Discussion Forum
Super C
Rick Hughes
02-23-2004 06:39:33
Just bought a Super C thats been sitting up a couple of years. Runs fine but the hydrolics won't work. Owner said they worked when he parked it and it had a cultivator on it which would mean it was working. Does anyone know if there is a filter that could need changing or anything that could be causing this.
Thanks
Rick
DoubleR
02-23-2004 19:57:22
 Re: Super C in reply to Rick Hughes, 02-23-2004 06:39:33
Had problems with mine too. Changed the oil and cleaned the screen which did,t help. Took the pump off and my local I-H dealer rebuilt it for 35 bucks. Has worked fine ever since.
Bill V
02-23-2004 07:57:09
Sounds like air in the system to me, I had a C and a Cub that did the same thing. Either drain and refill with hytrans or try adding.
Dave_Id
02-23-2004 07:22:01
First off, get yourself an owners manual, next drain out the oil, remove the screen from the side of the housing, and clean that, replace the oil with new HYTRANS from IH, then move the levers back and forth while running about a dozen times, and then top off the tank with more Hytrans. I"m guessing that you have air or water in the tank from moisture buildup..
