Tractor Talk Discussion Forum
STUCK IN NEUTRAL!
Herb D
02-19-2004 20:41:02
My 2N's transmission is stuck in neutral. I was wondering if I take off the upper & lower steering housings would that give me access to the shift forks and/or gears so that I might free everything up.
Thanks in advance for your help.
Herb D
old
02-20-2004 09:12:50
 Re: STUCK IN NEUTRAL! in reply to Herb D, 02-19-2004 20:41:02
If I remember right you need to take off the shifter plate not the steering parts to get in to that it will also be where you need to go/ do to fix your problem.
Danny
02-28-2004 05:02:38
 Re: Re: STUCK IN NEUTRAL! in reply to old, 02-20-2004 09:12:50
I have a 40' Farmall "A" model that occasionally gets hung up in 2nd gear. I have to take the shifter off and manually align the shifter and the transmission gears, both in the neutral position, to get it to work properly again. Maybe yours might be a similar fix?
