Tractor Talk Discussion Forum
jd model g knock
geo.herron
02-18-2004 16:20:17
i am new here,i stumbeld on to web sit and glad i did,there seems to be very nice people with a lot of knowlege, with respect i ask for some help.i have a 1950 g with slight knock, it seems in crank area, by useing a stethiscope i think this is area, i was wandering about plastigauge and removeing rod shims as nec. any other sugestions out there? i thank you all for any response. gh
DRL
02-19-2004 05:54:43
 Re: jd model g knock in reply to geo.herron, 02-18-2004 16:20:17
You may have already gotten an answer, but the first thing I would check would be the flywheel. They work loose from time to time, and this will make a knocking noise. May just need to tighten the bolts on the flywheel. Don't run it too long with this knock, whatever it is. If it is the flywheel, it will waller out the splines pretty quick. Good luck in finding your problem.
70 plowboy
02-18-2004 16:55:13
you might want to try to go to the john deere forum for that question
geo. herron
02-18-2004 17:24:34
 Re: Re: jd model g knock in reply to 70 plowboy, 02-18-2004 16:55:13
thank you very much for your quick responce, i will do as you sugested gh
