Tractor Talk Discussion Forum
New Holland 6610
mike
02-16-2004 18:51:22
I have recently bought a used 2001 6610 that was low on fluid. Now the lift won't work at all. It is in the down position. The hours on the tractor are low(175). Looks like brand new. Are there any adjustments etc. now that the fluids are correct that need to be made, or is this going to be something that needs major repairs? My other tractor is a 9n. I have never owned a tractor this size.
BLEED BLUE
02-20-2004 12:29:20
 Re: New Holland 6610 in reply to mike , 02-16-2004 18:51:22
DOES YOUR REMOTES WORK ? IF THEY WORK THEN, YOUR PRIORITY VALVE IS STUCK. REMOVE THE VALVE UNDER THE SEAT,REMOVE THE VALVES,BALLS & SPRINGS . CLEAN & INSPECT . THEN REASSEMBLE. GOOD LUCK.....
Flurette Farm
02-16-2004 19:45:15
Mike, I also have one of these tractors and though I have never experienced any problems of this type my 1st question would be have you gone through the manual and the trouble shooting section. You should also check because your unit if as you described should still be under warranty..... ..
