Tractor Talk Discussion Forum
John Deere 185
Darin
02-15-2004 09:40:00
I have a JD 185 with a 17hp kawasaki engine. After the engine is warmed up, it starts to lobe more and more until it finally dies. This is at full speed or at idle speed. After the engine cools, it starts fine. I've checked the gas and clean the carb. Any suggestions?
jimbo68
06-13-2005 09:51:51
 Re: John Deere 185 in reply to Darin, 02-15-2004 09:40:00
It may be a bad head gasket or a warped cylinder head. All related to an engine warming up.
bachert77
05-13-2005 16:50:06
Darrin, I have the same problem with my 185... What did the problem end up being?
Thanks, Brian
MJR
06-08-2005 13:12:55
 Re: John Deere 185 in reply to bachert77, 05-13-2005 16:50:06
Same problem(s); Had fixed a couple times-by Deere techs, but problem, keeps coming back, usually @ end of season. This year noticed that seems to be running on left cylinder only, (can remove R plug wire & keeps running, but other way no run at all. However, getting voltage out
Robert.
02-15-2004 10:25:30
Darin. I have an original operators manual on the John Deere 170-175 and 180-185 that may be of some value to you. Robert.
