Tractor Talk Discussion Forum
Tire weight
stan
02-14-2004 21:11:12
If I add water to my 18-4 x 38 tire How much weight will this add to the tire? Thanks, Stan
Dan in Wisconsin
02-15-2004 07:26:59
 Re: Tire weight in reply to stan, 02-14-2004 21:11:12
If you use just water at 75% fill you'll use approx. 110 gallons of water and add a weight of 920 lbs.. If you use a 2lbs. Calcium Chloride per gallon of water mix you'll use 100 gallons of water and 200 lbs of Calcium Chloride and add a weight of 1029 lbs.. Freeze protection +13 degrees (slush). If you use a 3.5 lb. Calcium Chloride per gallon of water mix you'll use 94 gallons of water and 328 lbs. of Calcium Chloride and add a wieght of 1108 lbs.. Freeze protection to -12 degrees (slush). If you use a 5 lb. Calcium Chloride per gallon of water mix you'll use 89 gallons of water and 445 lbs. of Calcium Chloride and add a weight of 1184 lbs.. Freeze protection to -53 degrees (slush). This is per tire data. If you have tubeless tires you should fill to 90% and all values would increase by 20%. Had to convert this from imperial gallons so double check. Should be close though. Dan
Rod (NH)
02-14-2004 22:03:23
Hi Stan,
Try this.
third party image Rod
