Tractor Talk Discussion Forum
h farmall
41farmall
02-11-2004 14:30:55
how much hp with 3 5/8' bore,300 gas head,350 cam,super h manifold,low low 1st gear
r4etired
02-11-2004 16:25:57
 Re: h farmall in reply to 41farmall, 02-11-2004 14:30:55
Dave I pulled an H in the 80's . Just took the sleeves out and ran AC D-19 3 9/16 pistons.Ran a 350 propane head Shortened the push rod side of the rocker arms to open valves further. Used a carb from a W9 burned alcohol. Ran 2250 Rpm. It would dyno 62 hp .
Nebraska Cowman
02-11-2004 16:19:05
in low low you should be able to spin the tires
