Tractor Talk Discussion Forum
White Tractors
Mike
02-06-2004 09:03:13
Hi guys,
Wondering what your thoughts are on white tractors. In particular the 4-150 and the 2-155. I would like to know if you think they are good or bad and what the Values are.
Thanks,
Mike
MK
02-06-2004 23:56:10
 Re: White Tractors in reply to Mike, 02-06-2004 09:03:13
The 4-150 4wd has a 3208 V8 Cat in it. Bad news!! You can buy them on auctions here for $5-$8000CAD because of the motor.
Mark
02-08-2004 16:38:32
 Re: Re: White Tractors in reply to MK, 02-06-2004 23:56:10
Since when is a Cat 3208 bad news. In the 80,000 lb 18 wheel rock bucket business, they were/are revered.
Mark
VADAVE
02-06-2004 10:43:37
There are folks that are going to disagree with me but...
Reading the literature it looks to me like the 2-155 is basicly a 2-135 with the turbo turned up. Now it may have some other improvements like different gearing and updated cab. Further it looks like White took the Oliver 2150 changed a few things like the sheet metal, the type of front weight, added a cab and maybe changed the gearing and called it 2-135. The guys I have listened to seem to really like them, further in my area the 2-135/2-155's are sought after.
The 2-150 has the huge 5--something Moline engine and I don't hear much.
IanC
02-07-2004 17:41:38
 Re: Re: White Tractors in reply to VADAVE, 02-06-2004 10:43:37
Clutch to PTO unit 2-135 & 2-155 are the same. 2-155 is 1000 rpm only from factory. You can put dual speed unit from 135 in but have to switch complete units. The only thing the same between 2050/2150 and 2-135/155 is the cubic inches, the motors are both Hercules, but are different models with little interchangability. The rear end, transmission, and hydraulics were completely different. Engine in 2-150 is 585 Cu.in., the rear end of that is the same as Oliver 2255.
what my neighbor did
02-07-2004 08:03:37
Was put the 5.9 cummins engine in his. I was at a farm sale and there was a newly converted nice looking White 2-135 with a nearly new 5.9 and it brought $8000 and was no-saled and a 6000 hour 81 model 1086 that looked like it had been ran hard and put away wet brought $15000!! That pretty well sat the value I thought but there is a good IH dealer close and fair White dealer closer
