Tractor Talk Discussion Forum
806 front end
cowmansam
02-04-2004 10:59:01
I noticed the front end on my 806 farmall is really loose in the center where it connects to main frame. I guess there is bushings or something that are worn out. It also has some wobble on the left side in the wheel and spindle. Would it be cheaper to find another whole axle or rebuild this one?
E J
02-04-2004 12:25:17
 Re: 806 front end in reply to cowmansam, 02-04-2004 10:59:01
You can buy replacement parts and bushings for your front end theirs after market or through a red dealer .Whats loose the wish bone or the bolster?In the wishbone theirs metal shims that you can take out of the ball socket the bolster you will need a new pin and bushings.I cheated and welded my steering arm to my spindal if it falls apart I"l cut it off wiyh a torch and replace with new.
