Tractor Talk Discussion Forum
Your carb should NOT leak......Carb 101
Scott
02-03-2004 10:01:07
Why is it that so many people suggest that the carb on your old tractor just might leak gas??? "Just shut the gas off", or "Some are too old and worn to get right", or some other statement to that effect!
I can't believe that people are so bewildered by a simple carb! These things on these old tractors are about as simple as it gets!
Let's have a carb lesson and put all those myths to rest. Your carb should NOT leak gas. You should NOT have to shut the gas off while not using it....I've got a 641 Workmaster that the fuel shut off DOESN'T EVEN WORK on it! It's froze in possition! (Yes, that shouldn't be so either, but I'm waiting for time to do the dog legs this spring, and my carb doesn't leak)
At the bottom, you'll find an article previously written, and free for the access right here on this site.
I'll also input some of my personal knowledge real quick. Don't bother with the environmentally safe carb cleaners. This being said, remove all jewlery before working. Good carb cleaner under the watch or ring burns bad! Also, for cleaning passages, if you don't have air, use needle nosed pliars to pull a wire from your wire brush. Their small enough to fit into the passages. (I turned wrench for several years on motorcycles...that's a proffessional tip I've not yet given out!) Follow the trails of the passages. Take a minute to look for all holes, and make sure they run carb cleaner completely through. If not, you've got a plugged passage.
MAKE SURE YOU USE SAFETY GOGGLES OR A FACE SHIELD!! CARB CLEANER WILL SHOOT RIGHT BACK AT YOU!!!
These things are simple! I've found that if it needs cleaned, and you don't have to take out the needles to get the carb cleaner to flow, you generally don't have to adjust anything when you're done! Floats don't change while being used, so if you don't change the needle, DON'T CHANGE THE FLOAT!
On the needle, my personal experience is that the triangular brass needle tends to drop out of the seat cleaner than the aluminum colored ones with the seperate head on them....must be the weight. That said, NOT ALL NEEDLES NEED CHANGED! Cleaning carbs on motorcycles, mopeds, 3 & 4 wheelers, I rarely changed needle and seats! Over the 5 years I spent doing this work, I probably changed TWO, and I've delt with some NASTY carbs! I am not bragging, but if I can take an abandoned corrosion FILLED carb and make it run, you can make yours work. Try grabbing the end of the needle while it's in the seat with a small pair of needle nosed pliars and giving it a twist while holding it in....this is seating it.
One last tip, and I'll stop my rant. Please try to work over a shop rag or three. In case you're afraid something might drop out on you, it won't roll away from you, and you'll be able to find it.
Now, GO CLEAN THOSE CARBS AND MAKE SURE THEY DON'T LEAK!!!!!
49 Cubber!
03-18-2004 14:36:17
 Re: Your carb should NOT leak......Carb 101 in reply to Scott, 02-03-2004 10:01:07
I see you shut up after my last post as Curious!You really struck a nerve on me,saying that you were better than me because you fixed a carb,whooooo oooo!you never once had the balls to say what kind of carb it was,or what you did to it other than clean it and set the needle valve.I guess the chances of you ever seeing this are slim but hey, Ifell a heck of alot better!
wes
02-04-2004 08:56:13
My owners manual says to turn the gas off and drain the carb if the machine will be parked for a long period of time. One thing you need to realize on this board is that not everyone has the same skills as you. Some people don't even understand what you are telling them to do. I for one can not learn from someone telling me what to do I have to see it. That is where videos come in handy. Just relax, drink a cold beer and sit back and laugh at this thread. I do find your info on carbs interestin but you might want to tone it down a bit.
Wes
Robert
02-04-2004 07:41:09
Just wondering----if I'm NOT supposed to shut off the gas (while the tractor isn't being used), how am I supposed to shut the tractor off?
I have a '45 JD A, with a magneto, no ignition switch or post on the magneto to ground it out, and I've been following the directions in the owners manual, which specifically states, that the CORRECT way to shut the tractor off, is to switch back to gasoline (this was an all fuel engine at one time), and shut the gas off at the gas bowl.
GG
02-03-2004 19:52:01
In my 58 years of life, I have worked on just about everything from a chainsaw to a bulldozer. I attribute my knowledge to interest and experience. There are very few people in this world today that have my attitude toward mechanical machinery. I do not think a secetary or a banker or high school kid could give me much advise on how to repair machinery but I will listen and will occasionally learn something new. For thirty years, I have worked for a large company, as a machinist, and all my friends know my mechanical ability. I can be in a room with ten people, someone will ask me a question about their truck, car or whatever, and they will get five answers from people who don't even change their own oil. All these answers come before I have a chance to answer! I realize that this is MALE human nature, and it doesn't bother me. You win RESPECT from being right and not bragging. I never laugh or make fun of people less knowlegable then me because I know they can teach me something. I learn something new every day and frankly am surprised at the knowledge that is in this forum. In the past, I have asked questions, as a test, and found that several people knew what I knew and sometimes more.
varmint
02-03-2004 18:46:10
What was it, man? Bad drugs, lousy childhood or WHAT????
Thanks!
02-03-2004 17:58:05
for bringing up a subject that, apparently has touched a nerve, and adds to the sharing of information on this board. When the air is cold and the snow deep some subjects 'heat' things up. Can't wait for warmer weather;-) I personally hate a leaky carb and hate a leaky cut-off even more. Stay warm.
HTR
02-03-2004 17:55:42
I turn the gas off about once out of a hundred times. I have noticed that it only leaks about once out of a hundred shut downs, so I try to hit the right time.
Loren
02-04-2004 19:24:13
 Re: Re: Your carb should NOT leak......Carb 101 in reply to HTR, 02-03-2004 17:55:42
That's a good one. I try also, so my tractors have resorted to leaking more often!
Chris Brown
02-03-2004 17:52:04
Well put Scott! The only thing I would add is that a propane torch to warm the casting to release the brass tubes.I have found a bernzomatic is a good friend when resurrecting an old carburator. I have put the parts on the oven but my wife complains mightily.
raytasch
02-03-2004 15:41:16
Scott, Interesting take on the subject but one small question. What happens the FIRST TIME you get that small piece of crud that found its way past the venders filters, your filters and gets caught between the float valve and seat? So sorry I got in on the thread late. ray
Cosmo
02-03-2004 14:40:39
I would like to apologize. I have a carburetor that seeps a bit of gas. I can't find any rebuild kit or even a replacement. I keep it in an enclosed building and I DO TURN Off the gravity fed gas. I'm sorry you had to hear about this. Sleep well.:)
Scott
02-03-2004 15:02:11
 Re: Re: Your carb should NOT leak......Carb 101 in reply to Cosmo, 02-03-2004 14:40:39
Cosmo, not all hope is lost. If you don't know your way arround a carb, either take it off and bring it into your local shop and ask them to help you a bit. May cost a few dollars, but shouldn't be much.
If you do turn a wrench once in a while, it's not that bad a deal. Read the article that I posted a link to (not mine, but it is good) Near the end (several pages) he shows the measurement for the float....your's may be a little different, so just measure yours and raise it a bit farther off the top of the carb. NOTE this would mean lowering the float in the bowl, (carb is shown and adjusted upside down from mounting possition)say 1/32" ....use a drill bit of the right size to get your measurement. While you're in there, give it a good rince down with carb cleaner. If it's running right, don't mess with the adjustments, just the float. Also, seat the needle like I described above and make sure that area is clean.
Hope you get her fixed up.
Cosmo
02-03-2004 16:24:01
 Re: Re: Re: Your carb should NOT leak......Carb 10 in reply to Scott, 02-03-2004 15:02:11
Scott, thanks for your reply. I have turned a wrench or two in six decades. But with no hope of getting a kit this side of New Zealand I think I'll not dismantle this carburetor again and have to spend a couple of hours whittling out a new gasket. As I said, it seeps a little and does not drip. I can live with the loss of a couple of gallons or less a year and it really isn't that much of a strain to shut off the gas. Thanks, Cosmo
I Know One Thing
02-03-2004 13:41:15
Interesting discussion and from all the reading I have only learned one thing for sure, and that being the fact that if I lived next door to Scott, I would definitely have to be restrained. Speaking of motorcycles, there used to be a column writer in Dirt Bike Magazine back in the 80's (maybe he's still there) by the name of "Mr. Know It All". No question, Scott is the same guy in tractor drag!!!
I beleive the term.......
02-03-2004 14:17:05
 Re: Re: Your carb should NOT leak......Carb 101 in reply to I Know One Thing, 02-03-2004 13:41:15
is seckual intellectual
02-03-2004 14:35:08
 Re: Re: Re: Your carb should NOT leak......Carb 10 in reply to I beleive the term......., 02-03-2004 14:17:05
No such word
Cant type what
02-03-2004 19:25:01
 Re: Re: Re: Re: Your carb should NOT leak......Car in reply to ???, 02-03-2004 14:35:08
I want,filters!In short F%^&*&^ Know it all!
Scott
02-03-2004 14:11:51
And you'd have to bring a sack lunch should you escape.
Put away your little bernzomatic torch, and bring out the real flame thrower. I wear asbestas underwear, so all your flaming does is give me a nice summer breeze. Feels good in the middle of the winter.
And for your information, it's "Mr. Fix It"
been there before
02-03-2004 13:38:35
Good carb or bad, you should shut the fuel off if the tractor is going to be sitting for more then a few hours. Don't be so damn lazy.
tractorhead
02-05-2004 05:10:15
 Re: Re: Your carb should NOT leak......Carb 101 in reply to been there before, 02-03-2004 13:38:35
for many years i never shut my gas off at the end of the day, one morning I found my entire gas tank drained on the barn floor, scared the crap out of me.Ill never let that happin again. jimmy
Ben in KY
02-03-2004 13:54:28
The petcock on some tractors is easier to get to than on others. Mine requires putting your face against the loader valves and such to reach the shutoff valve :(
Curious?
02-03-2004 12:40:42
Your point is?Why the rant?Did someone here make you mad enough to post this.I just dont get it!Some carbs are too old to get right,and too worn to get right and parts DO NOT exsist for every carb in the world!
Scott
02-03-2004 13:00:56
 Re: Re: Your carb should NOT leak......Carb 101 in reply to Curious?, 02-03-2004 12:40:42
Curious, I sure hope you know what you're talking about, because I definately do, and I say it can be fixed.....you've not seen what I've worked on. You couldn't tell it was a carb.
Curious?
02-03-2004 14:15:32
 Re: Re: Re: Your carb should NOT leak......Carb 10 in reply to Scott, 02-03-2004 13:00:56
Oh so now your an expert carb builder.You rebuilt the unrebuildable carb.Wow!Im impressed.tell ya what,Ill send you my carb from my old F12 and I dare ya to find a new float for it,not used,NEW!I dare ya to find the idle adjustment seat,NEW!Cant be done cause nobody makes'em.I had to buy a used carb,rebuild it wit hwhats out there and let it go.I have no other choice!Yea!If i leave the gas on on the starting tank,thats on the hood,itll leak,NEW needle and seat.It doesnt leak past the gasket,but down in carb to the pistons!SO when I need tro run it for a bit ,if iI left the gas on its flooded and wont start.Why do I not adjust the flaot,well since new flaots are available I have to use what I got to work with.I dont claim to know everything abpout carbs,such as yourself,and I do have some experience with dirty,corroded rusty old carbs,but I dont go around bragging about it,or lecturing others about what they do wrong.
Scott
02-03-2004 14:53:21
 Re: Re: Re: Re: Your carb should NOT leak......Car in reply to Curious?, 02-03-2004 14:15:32
Curious,
Yes, I could probably fix it for you, but that would do you no more good than someone making one payment on your credit card...helps, but doesn't fix the problem. And for your flaming, I'll suggest I never said anything about new this or new that. Fix the thing! Sure, you may not be able to get cork floats anymore, but cork is cork. Brass? Well, you might know how to solder, but that's another lesson. Don't come into my thread and start bit*&^$% about this and that! Was it you bobique that suggested this on an N board lately??? Since when couldn't you find N parts? I can find them today at the local farm suply store..... .in a non-farming community! Don't try to rash my arse by splitting hairs, it don't fly.
Now, for the helpfull me. You may have just stumbled onto part of your problem. Your distillate may just be some of your problem. There are several complaints in the small engine idustry about this eating away at gaskets and seals. When our equipment was built, rubber was not a widely used substance. I've seen metal needles and seats. I've seen cork floats.
Tell ya what, post up your problem in tractor forum and I'll see if I can be of any HELP to you. I had no intention of burning you on your problem, just that you offer this up to unknowing folks that are trying to get an answer. As you know, gas leaks are dangerous, and I hate seeing people even hint on letting it leak. Someone here posted up on a close call on a motorcycle. I deffinately don't want to be a part of that being MY advice. I don't know it all, nor do I pretend to, but I do know carbs rather well. I WILL HONESTLY TRY TO HELP YOU IF I CAN.
Curious even more now!
02-03-2004 16:01:02
 Re: Re: Re: Re: Re: Your carb should NOT leak..... in reply to Scott, 02-03-2004 14:53:21
Ok Ill bite,but a few facts first!I dont run distalte in my carb,or kerosene or anything else but gasoline.the floats,that IO have come across rae NOT cork,but brass,I can solder,no porblem there.Now,say the bracket for the float pin is wore out.Now,how many carbs should I buy just to get this bracket,10,20 maybe more beforeI find one that isnt wore out.These little brackets arent available new,most parts folks wont sell just that peice,you have to buy a whole carb!Next,a float,same deal!Try to find a kit that isnt filled with generic parts and gaskets for this thing!Most,if not all have the gaskets,needle and seat,throttle valve and thats it.
Carb on my 12 has been cleaned and cleaned and cleaned!Things are wore out on it that cant be replaced with NEW parts,and again,how many carbs or peices of carbs should one buy to get one little peice.
Now,I dont own a dang ford tractor and I dont know who you think I am,but Im not who you think I am!
What did this carb you fixed go on? Idont recall seeing that.
As for flaming,well Ill let every one else decide if Im wrong or not and appologize if I am. Idont think so. I am just expresswing my opinions on your "boasting" of fixing a carb and telling others how wrong they are.
Bob
02-03-2004 13:10:56
Scott, I agree with you. It amazes me the number of people that buy a new carb, even an imported no-name knock-off, because they do not realize their old carburetor can be repaired, or they install a new carburetor without cleaning the fuel system, and installing a good filter. Soon, the new "good" carburetor behaves just like the old "bad" unit.
We do a lot of repair work on older farm-type vehicles, and some people DEMAND a rebuilt carburetor. With some exceptions, I cringe at the thought because of some of the cobbled-up factory rebuilt carburetors we've seen these last years. Apparently, good cores are hard to come by, and the rebuilders sometimes use cores that should have been scrapped.
markct
02-03-2004 12:33:05
i remember a few years ago i had an old yamaha dirt bike with a leaky carb, rode it for months just turning off the fuel, well one day a friend pulled in the yard, i rode up next to his truck and turned it off and started talking to him, well all the sudden he got all excited about something, well he was all worked up cause he realized before me that my motorcycle was on fire, so of course i jumped off and threw some sand on it, put it out, then it sat in the shed a few months till i got it out and thought i fixed the carb, well sure enough i was out riding across the field when i felt my thighs getting warm, so i stopped and layed it down in the dirt, big fire that time and never had to mess with the bike again, straight to the junkyard. sure was burnt to a crisp, glad it wasnt a tractor or anything, i had only paid 25 bucks for the bike so no big loss
Why do they leak??
02-03-2004 12:00:23
Thanks for your posting and the link but neither one tells you which the offending valve is and what to look for when you carb leaks other than a total rebuild.
Scott
02-03-2004 12:55:06
 Re: Re: Your carb should NOT leak......Carb 101 in reply to Why do they leak??, 02-03-2004 12:00:23
third party image
Here is the parts that are subject. This is one of the last two pictures on the page I gave you. One of these parts has to do with it. Big brass thing is the float, needle and seat are under it, better shown in the next pic on the page. What was said below is correct.
Think of it like your toilet. If the float is too high, the water runs to the over flow (out your breather hose or carb gasket). Needle bad is like the shut off being bad, ie: toilet keeps running water in and right back out the over flow.(carb leaking a little over time will cause it to go over and leak out the air inlet). If you poke a hole in the float, it won't float back to the top....just like a carb.
Bob
02-03-2004 12:27:36
On a carburetor such as the one in the link posted there are only a few possible causes for the carb to leak when the tractor is sitting unused.
1.) Gas leakage that passes THROUGH the needle and seat, due to foreign material in needle and seat, or damaged needle and seat, including wear or scuff marks on the needle that cause it to jam in the bore of the seat when lifted by the float.
2.) Gas leakage that passes THROUGH the needle and seat, due to a leaky float that has gasoline inside, a bent or damaged float that catches against the side of the float bowl, and doesn't lift and tightly close the needle. Some carburetors have a FLOAT DROP adjustment that, when properly set, prevents the float from dropping clear to the bottom of the float bowl and jamming there when the float bowl is empty.
3.) Gas leakage that does NOT pass through the needle and seat. This might be due to a defective or missing gasket between the seat and the carburetor top cover, or the seat not being SECURELY TIGHTENED into the upper carburetor body. In rare, freak cases, there could be a flaw in the casting, allowing the gasoline in the passage fed by the fuel line to leak into the float bowl. I believe the bad or missing seat gasket, or inadequate tightening of the seat are a couple of the more common causes of a carb that drips.
Anybody else have other causes of carburetor leakage to add?
Ben in KY
02-03-2004 12:24:29
It is generally the float valve. Could be because of gum in the carb, a bad float valve, sticky/binding/worn out float hinge pin, or bad float. This is assuming the carb was put back together right the last time.
It could also be dirt/rust in the gas causing the needle valve to stay open or a leak around a line or something going into the carb.
I have learned by experience to fully clean and service the carb anytime I have to work on one, otherwise you will probably have ongoing problems with it.
Steve W (NY)
02-03-2004 11:27:23
I always shut the gas off when I park my tractor in my garage. Why? Because the risk of ten gallons of gas on the floor is not worth the risk of dumping it on the ground. Unlike a car, with a fuel pump, my tractor is a gravity fed system. If the float bowl leaks, the gas pours into the air cleaner, or into the carnkcase, well, that is a problem. Plus if ten gallons of gas gets into my groundwater, I would consider that a problem too. As an owner of many vintage motorcycles over the years, with similar float sytems, trusting them is a mistake.
I agree, if you own a tractor with a leaky fuel bowl, you are a fool if you don't fix it. My stuff I keep in tip top shape.
One other good reason to shut off the gas....I once had a tracor "borrowed" for about 60 feet. Luckily they didn't know why she quit.
Hope I didn't put the jinx on you. LOL
Take Care
Steve
Nolan
02-03-2004 11:25:18
I'm glad for you Scott. Having owned many a motorcycle and tractor that had specific instructions to turn off the gas petcock when not in use though, I'll differ from you in the conviction that there is no call for turning off the fuel. Having had many of those pieces of machinery drain a fuel tank at some time or another because the needle stuck or simply because the oem float isn't adequate to permamently withstand the column pressure of fuel... Well, I'll just turn my fuel petcock off and not ever have to worry about it.
Scott
02-03-2004 11:42:22
 Re: Re: Your carb should NOT leak......Carb 101 in reply to Nolan, 02-03-2004 11:25:18
Nolan, you're missing the point. Yes, it's a good idea to turn off the gas for just the reasons you're listing. I'm talking about the habitual offending carb. Ya know? The one that NEVER stops leaking gas?
This is another problem; I'm posting on how people don't know or want to fix their stuff, and someone always has to post up an argument ...Well guess what, you're not fixing your carb by shutting the fuel off, you're safeguarding your investment....good to do, and good advice...still off subject.
Scott
02-03-2004 12:31:35
 Re: Re: Re: Your carb should NOT leak......Carb 10 in reply to Scott, 02-03-2004 11:42:22
Ya know nolan, I woke up on the wrong side of the bed this morning, so let me elaborate a little more.
You said you've owned motorcycles....did you know that since the 1980's, or even sooner they have been putting a vacume fuel shut off on the major majority of the motorcycles? You're just turning off the gas as a safety factor....doubling up. Why do you think the mfg recomend it? People have had fuel leaks due to improper fuel system maintenence, fuel has leaked out, and damage has resulted. The motorcycle industry gets sued over it and loose their arse. "CAUTION: COFFEE HOT!" Ring any bells?
Your tractor has leaked out gas? Definately not over night, or you need to be looking at a carb clean and a tank cleaning. If your fuel supply is perfectly clean, and you don't let it sit long enough to go stail, much less varnish, it shouldn't leak. Go fix your stuff. They didn't build these things with too much "columb pressure" to begin with, so something must be wrong.
End rant
Ben in KY
02-03-2004 11:12:02
I agree, I never turn off my gas petcock. If your carb leaks it is a fire hazard and your engine will probably not perform as it should.
However, just because someone owns a vintage tractor doesn't mean that they know any repair procedures at all. How many of us have seen a posting like " My tractor won't start, what is wrong".
Then there are those like my father in law who cobbles something up and says "that will work". This is ok for a temporary field fix, but these temporary fixes usually becomes permanent till the whole machine becomes a cobbled mess, and is declared a piece of junk, I then hear " I will never buy that brand again it is junk ".
Oh well...
Bob
02-03-2004 12:47:44
 Re: Re: Your carb should NOT leak......Carb 101 in reply to Ben in KY, 02-03-2004 11:12:02
Ben,
I also never turn off the gas on my old 8N Ford, because the carburetor is in good repair and does not leak. The problem is, sooner or later, any carburetor is gonna have a fit, and, in the case of a gravity flow system such as this, one day we'll come out to start one of our tractors, and the machine will be sitting in a pool of however much gas is in the tank.
It sure makes you think what could happen, fire or explosion wise, when this happens.
I admire people who have the sense to shut the gas off, just in case, and I need to heed my own advise and start doing that myself!
Scott
02-03-2004 11:34:22
Ben, you are exactly right, but I really can't start calling people too cheap to have a mechanic look it over. That would be calling the kettle black (old expression, let's not get pollitical).
I have figured out that I'm a little different from some folks in that I am mechanically minded. These things just make sence to me, where some it doesn't register the same way. To those people, I might suggest removing the carb and taking it in if you want to save money....sorry, but I don't have any advice other than to look it over good and get the gist of how it works before you tear it apart....Please don't tell someone else that is just is going to happen and there's nothing they can do!
rod
02-03-2004 15:11:36
 Re: Re: Re: Your carb should NOT leak......Carb 10 in reply to Scott, 02-03-2004 11:34:22
take it to a shop?? ha most of these guys have never seen a 50 year old carb lots are very hard to get parts for I have seen some that were rebuilt that leaked worse than before the rebuild the local tractor dealer had a beautiful big new truck that I am sure I helped finance I would not let them put a screw in drywall let alone work on something they could bust.
regards
rod
Scott
02-03-2004 15:27:29
 Re: Re: Re: Re: Your carb should NOT leak......Car in reply to rod, 02-03-2004 15:11:36
Rod, you couldn't be more right in some cases. The ford that I delt with WAS rebuilt at the shop per the request of my father a couple years ago. I had to completely re-do the needle and seat and float adjustment myself in order to get it to work right.
Maby the best thing would be to try to find some local older gentleman that does mechanics....a little easier to find in the small communities, but I find their knowledge is sometimes unbelievably in depth. GREAT resource for those that like turning wrench on old iron. I've heard a couple storys from some of these guys and learned a lot....great.
Ray
02-04-2004 08:13:37
 Re: Re: Re: Re: Re: Your carb should NOT leak..... in reply to Scott, 02-03-2004 15:27:29
I always shut off my gas, even though my carb doesn't leak. I've found that most of my carb problems (in my '59 IH T340 and small engines) is related to gas evaporating and leaving gum/varnish in the carb. Since I started shutting off the gas in these engines, my carb problems have almost disappeared.
Ray
