Tractor Talk Discussion Forum
case sc clutch
jon
01-31-2004 20:21:48
When I was mowing with my Case SC tractor and brush cutter the tractor quit moving. The engine will run but the tractor will not move. I figured it is a clutch problem. I pulled one of the side covers off and spun the engine by hand and in neutral the input shaft spins. When you put it in gear or engage the pto, the input shaft quits spinning. Also there was very little grease in the housing. My question is does there need to be grease in the housing for the clutch to work or is the clutch worn?
Dan (nj)
02-01-2004 16:36:06
 Re: case sc clutch in reply to jon, 01-31-2004 20:21:48
The clutch is an oil bath, meaning it should have engine oil in the clutch housing. That said, the input shaft should turn when the clutch (hand clutch?) is engaged, regardless of whether it is in gear or not. Transmission problem? HTH, Dan.
