Tractor Talk Discussion Forum
Pertronix Flame Thrower high performance coil
Wayne M Kittler
01-31-2004 11:06:19
Pertronix "Flame Thrower" high performance coil ?
Is this an improvement for older gas engines?
buickanddeere
01-31-2004 14:29:38
 Re: Pertronix Flame Thrower high performance coil in reply to Wayne M Kittler, 01-31-2004 11:06:19
Will it make a worn engine start and make HP like it was new, no. If used with stock points the higher current draw will shorten thier life compared to a stock coil. If the plug only need 20,000V to jump the gap, that's all the voltage a high output or stock coil will make. The high output coil may deliever more current depending on it's internal design. If the higher volatge and current capabilities don't jump the spark across the inside of the distributer cap/through the boots and over the plug exterior. It will allow a wider plug gap which is more resistant to fouling and ignites a lean mixture with more success.
jocco
01-31-2004 13:44:32
i have used pertronix ignition parts and they work good especially point to electronic conversion.
