Tractor Talk Discussion Forum
Repair Rear Tractor Wheel
Tom
01-29-2004 18:49:08
I was changing the rear tires on my tractor and the rim is baddly rusted and it has a hole rusted through where the valve stem goes through. I thought about having it sandblasted and then go back with some fiberglass and repair the hole and then drill a hole in it for the valve stem. Would this work? Any advice would be appreciated. Thanks
bob
01-29-2004 20:16:50
 Re: Repair Rear Tractor Wheel in reply to Tom, 01-29-2004 18:49:08
I have cut a good hole out of a bad rim & welded it in. Saves drilling & its exactly right size.
Northern Ca.
01-29-2004 19:13:18
I have Cut Off Some Bad Part Of Rims & Welded a good Part Of rim Back. My Local les schawb said Cant mount A Tire On welded rim , But they Couldnt Tell Where i Welded it. Tires Mounted & All is o.k. go Figure
steve
01-29-2004 18:55:41
i have seen that done if you have good structure around the area. aexamine after sand blasting. it is common to have someout cut out a section and wire feed weld back a plate, maybe 3 or 4 inches square, then cut a hoe for the tube. you can grind down the weld and paint and looks great if you take your time fitting the steel plate.
greg
01-29-2004 19:24:01
 Re: Re: Repair Rear Tractor Wheel in reply to steve, 01-29-2004 18:55:41
I have welded the hole shut , and then gone around the rim 180 degrees and drilled a new hole for the valve stem, deburr the hole and have it mounted up.
Terry H
01-30-2004 06:44:30
 Re: Re: Re: Repair Rear Tractor Wheel in reply to greg, 01-29-2004 19:24:01
Same here. No problems.
Terry H
