Tractor Talk Discussion Forum
Silage Blower
Grant
01-28-2004 13:05:06
I have a NH silage blower (do not remember the number but I will find out). I want to blow sawdust and shavings 6 - 700 feet out into my my field. I have a bunch of 8 inch and 6 inch aluminum irrigation pipe which I could connect and lay out to the field. There is no elevation gain, and I just want to blow it into a big pile so that I can spread it with my cat.
I could truck it out with a couple of single axle dump trucks and a big manure spreader, but I think it will take too long (labour intensive)and the fields are really wet until June.
Any thoughts as to whether this would work or if it is too far to blow the sawdust. I know they blow a lot of sawdust in mills etc.
I know the blower works, but I have never used it, I do not even know why we have it. We always filled our bunker with trucks and loader and we never had a silo. Dad must have got a good deal.
Grant
01-29-2004 07:55:19
 Re: Silage Blower in reply to Grant, 01-28-2004 13:05:06
Thanks everyone for your thoughts. It appears the majority of you do not think it will work. I guess the only way to find out is try.
The ground was frozen for about a week the start of Jan, we almost got out skating, then it rained.
The water table is very high right now. I will start pumping my fields out soon, but there is constant hydrolic presure from below to replace the water just removed.
I will let you know how it worked out.
sod
01-29-2004 07:04:01
Can't you sell that stuff?
good luck
sod
sod
01-29-2004 07:05:13
 Re: Re: Silage Blower in reply to sod, 01-29-2004 07:04:01
the chips and sawdust, I mean.
sod
bob
01-28-2004 21:36:33
Nope won't work. Been there, done that. Had silage blower on sawmill. Had to shut down every 15 minutes to shovel. Dust is too fine. Will settle long before it gets there. Silage is big & air gets behind it & drives it. I'd be surprised if it blew it 100' with someone shoveling it in. It wont pick up the dust at all.
Bill
01-28-2004 18:47:49
You don't say where you are. Is the ground frozen? We pull spreaders all winter in Wis. Can't do it in the spring when thaw time comes. It would be fun to try the blower trick though. You'd be the talk of the town if it worked.
Alvin NE WI
01-28-2004 18:05:15
you will not be able to blow that stuff on a horiazatal{?} pipe because your blower is not running fast enough, than it will settle down in the pipe and plug. Going up a 100' silo is at a different direction and they plug sometimes also. Just my .02 cents thoughts.
Alvin
Bob Clark
01-28-2004 17:55:11
I assume your using the aluminium for testing because you will eat it up very quickly. As to how far you can move material I don't have any real experiance but you remember you are throwing silage up. My brother-inlaw used to do custom silo filling and I remember him saying that if the pipe was angled (for instance if the blower was a few feet away from silo across a fence) it plugged much easier.
Most air material systems require a lot of air to function well.
Daniel
01-28-2004 17:25:42
It will work if you saw dust is dry.
I work at a paper mill where we blow wood chip at more then 1100 feets. The only problem with this installation is when we have an air leak in the pipe, then this create a jam in the pipe.
So you pipe has to be without any air leak.
russ
01-28-2004 15:23:18
i hate to say it you might blow it 200 feet but thats it, i think your gonna waste precious time, sounds like you should get a hold of a 300 to 400 bushel spreader ang get it over with ,the best you can with wet conditions
333
01-28-2004 14:19:32
You can blow wet corn silage about 100 ft straight up, with a 1000 rpm blower, at a pretty fast flow, 4 minutes to empty a big wagon, if the saw dust is dry and you are blowing horizontilly also limiting the flow maybe 3 to 400 ft I doubt if 700 would work but it could be possible ,let me know if it works, wouldn't take long to try blower pipe is easy to put together.
paul
01-28-2004 13:22:04
I do not know, but please bear with me. It was minus 11F for a high today, I have cabin fever so I'll reply for something to do....
I'm thinking corners will kill you, you would need a straight shot.
Is it all granular sawdust, or any splinters & strands to get stuck? Plugs will be a bear to work out.
You will end up with a pile out in the field, not sure if you want it spread or piled?
With grain vacs it's easy to pull grain around all kinds of bends & such; but much harder to push grain. It's easy to set up the airflow & introduce as much grain as works to pull. Hard to guess how much air to use to push - too much air wastes power, too little air makes plugs. Probably the same here?
Like I said, just the numbness talking...
--->Paul
