Tractor Talk Discussion Forum
new engine oil
stan
01-25-2004 17:42:57
I am just about finished with my 3 cyl perkins diesel rebuild. What would be a good break in oil? Growing up, we were always told to use non detergent by the old timers. Now I am the old timer. The last engine I rebuilt was a ford 400, and I used detergent oil, and it seamed to be ok.
Jimmy King
01-26-2004 06:06:47
 Re: new engine oil in reply to stan, 01-25-2004 17:42:57
I have a friend that is a grad. of a diesel school, and 14 years at a Cat dealer before he went to farming full time. He has overhauled two diesels and two gas for me put Rotella in them from the get go said run them easy for 100 hrs then he wanted to run the over head again.
T_Bone
01-26-2004 05:21:40
Hi Stan,
With the new oils being produced today, I wonder just how important break-in oil is vs just using a good grade diesel oil.
My PSD came with 10w30, CH4, from the factory and I ran it for 5k before changing to Delo, CI/SJ. Ford doesn't use break-in oils in there engines any longer.
Some of the light weight diesels are coming from the factory with synthetics. No more dino break-in before syn. use.
T_Bone
kyhayman
01-25-2004 19:26:24
All I've ever used, right or wrong (in a diesel) is HDX/FCI 30 weight Quaker State. Run it for 9 hours and drain it (3 hrs each at 1400, 1800, and full throttle). Then I put in Rotella 15w40 (my regular oil) and run (without lugging) for 50 hrs. Then change again and use normally
