Tractor Talk Discussion Forum
345 IH V8
r4etired
01-18-2004 16:38:17
I'm looking for a running 345 IH V8. They were used in the 915&815 combines. I prefer the combine one because it has a govenor. Anybody out there put on in an M farmall Just finished putting one in a 560
r4etired
01-19-2004 19:16:52
 Re: 345 IH V8 in reply to r4etired, 01-18-2004 16:38:17
THE345 worked well in the 560. as I used one from a combine the 560 clutch will bolt right to the combine flywheel. The combine 345 flywheel is about 1 in bigger in diameter than the 560 flywheel. I turned it down to accept the 560 ringgear. It also requires a spacer between the crank end and the flywheel to line up the clutch and starter.You don't need an adapter plate I just redrilled the rear engine support. worked fine.
Robert Cornell
01-19-2004 06:02:27
try the classifieds on www.binderbulletin.org or www.oldihc.org
Dave in GA
01-19-2004 04:01:59
I've got a truck with the 392 engine. It's strong and reliable. IH made some tough V8s.
BEN K
01-18-2004 20:57:37
Lots of torque I have been playing with theas for years In scout 4x4 s. A nother good source I have used is I H school buses note 152 196 304 345 392 all use same mounting holes just mix match preashure plate and flywheels
doorguy
01-18-2004 19:13:16
Please tell us more. I have a 560D with a bad motor and this sounds interesting thanks doorguy
russ
01-18-2004 18:11:01
you said you just put one in a 560 please tell us more did you fabricate adapter plate or buy it sounds interesting
Dave
01-18-2004 17:59:06
I have one from a Grain Truck that ran when it was taken out. If interested call 1-630-820-2607 and leave a message, I WILL return your call. Located in N_E IL, could deliver.
Fred OH
01-19-2004 08:47:38
 Re: Re: 345 IH V8 in reply to Dave, 01-18-2004 17:59:06
Come to think of it I have a 401 cu. in. International engine that came out of a 73? International Travelall. (Does that sound right?) All because it had a bad rear main seal and the previous owner couldn't find one. Other than that it has a quadra-jet four barrel carburator and has an automatic transmission attached. I'll sell it too. I'm in southern Ohio. PUOnly. Fred OH
