Tractor Talk Discussion Forum
Starting problems Ford truck
Mark/Wi
01-18-2008 06:45:17
I have a 77 Ford 250 with the 400ci. for a snow plow truck. When it warms up, the starter won"t turn it over fast enough to start. If you leave it sit awhile it will start fine. The timing is correct. Any help with this would be appreciated. Thank you.
PS there is no indication the it is overheated.
RodInNS
01-18-2008 13:19:06
 Re: Starting problems Ford truck in reply to Mark/Wi, 01-18-2008 06:45:17
I'd guess that the advance is sticking or some other timing issue. Back it off some and see if it starts.
From what I've seen of bad modules on Fords, they just plain won't start or fire when the module goes south. We used to carry a spare module behind the seat for our old ton with the 351 windsor...
Rod
teddy52food
01-18-2008 10:47:40
I agree with Dave in Texas. The retard curcuit in the control box has gone south.
hay
01-18-2008 08:25:16
some vehicles have the exhaust pipe very close to the starter and when the engine is hot it makes the starter not work correctly. some GM and Chevy trucks have that problem and maybe some fords. some type of heat shield might be the solution to the problem.
Gerald J.
01-18-2008 08:23:32
Centrifugal advance sticking advanced. Slides back as it sits.
Gerald J.
old
01-18-2008 07:59:44
If when its turning over the engine spins fast then slows down and then spins fast again your timing is off. Common problem with a timing chain that has see a lot of miles. And from what your saying that sounds like your problem. Back the timing off just a tad and if it stops your problem then you know the timing chain is getting old and should probably be replaced, and if you replace it don't forget the sprockets
rrlund
01-18-2008 07:58:35
My vote is for it just being so loaded up with carbon that it's increasing the compression. We tend to forget old problems like that with these new electronic fuel injected modern engines.
georgeky
01-18-2008 07:42:01
Could be the starter, out of time a tad or even a bad cell in a battery. How do know timing is correct? When timing chains are stretched a tad the light doesn't even work real well on them. I have had several of the electronic ignition boxes go bad, and they all just plum quit when they went. I carry an extra one in the truck with me.
trucker40
01-18-2008 07:41:03
Ground cable from battery could be loose or corroded where it bolts to the block.Starter maybe is wore out.I would check all the cables first.
RustyFarmall
01-18-2008 07:08:14
Probably the bushings in the starter are worn, allowing the armature to "drag" on the fields. When everything is warmed up good, the steel in the starter will expand, and this makes the starter drag even more. You can replace those worn bushings, but if the armature has been dragging against the fields long enough, the damage is done, and your best bet is a complete rebuilt starter.
Ford 312
01-18-2008 06:50:43
Might try checking starter. As I recall, a worn starter will turn over slower after getting warm.
Dave in Tx
01-18-2008 07:30:19
 Re: Starting problems Ford truck in reply to Ford 312, 01-18-2008 06:50:43
If it has the electronic ignition box on the wheel well, they will go bad and not set the timing back to start. 90 yr old Ford mech. told me that one day when I was having problems. Put a new one on, no more problems.
