Tractor Talk Discussion Forum
4 WHEEL DRIVE 4000
Rick
01-16-2004 11:05:48
I have been looking at a 4 wheel drive 4cyc. 4000 with front loader and bucket and a 14 foot backhoe.The tractor's all four wheels are the same size 13-6 by 24.The loader and backhoe are industrial, it has clutch steering , 172 cu. in. motor , 4 spd. trans. with shuttle shift.The left side wheels are hooked together with drive chains, so are the right,it steers like a track machine.It looks like it was made by another company with Ford partsThe two questions I have are has anybody seen one of these and what do you think it is worth, it is all there and runs good, backhoe good front bucket needs work
Taylor Lambert
01-18-2004 17:47:58
 Re: 4 WHEEL DRIVE 4000 in reply to Rick, 01-16-2004 11:05:48
Ford / COunty tractors used combination steerting I thing the tires on the front turned a little then thye skidded. if it has a backhoe and the shuttle shift Id put money on it as being a Ballmar Tractor. It was a ford conversion as well and it was converted over here. Ll the parts are off shelf Items. Ive seen quite a few and a friend of mine had a 2000 Ford/Ballmar that had a loader he used a few years as a skidder. Ive seen them as trenchers having dozer blades, and full backhoes, a few as forklifts. a couple with Hyster cranes. I saw one last year a 4000 with pan on the back and blade on the front. I saw 3 on a pipeline job onetime that had side booms and angle blades on them for laying pipe and backfilling. They were mainly a prime mover unit for different things.
Brokenwrench
01-17-2004 17:42:17
I believe what you have is a Country conversion. This Brittish company converted ford tractors to the configuration that you have. They were made for muddy conditions and were mostly found in Europe. The company is still in business,but doesn't do conversions anymore since the advent of 4wd.
Alvin n Ms.
01-17-2004 08:18:45
Rick, I never saw one and I wouldn't pay much above the salvage value. It sounds like trouble. Its your money, Goodluck, alvinnms
