Tractor Talk Discussion Forum
b. young did you fix ih 240 steering?
deano
01-15-2004 17:30:06
i was wondering if ya figured out and fix the problem..i've been working on my 240, and was curious if ya figured it out yourself, or if ya can't ask it on the farmall site, someone will fix it..
Slowpoke
01-17-2004 01:08:24
 Re: b. young did you fix ih 240 steering? in reply to deano, 01-15-2004 17:30:06
Hi, Deano I'm working on a IH240U starter. Can you tell me what is used to carry the power from the solenoid to the interior of the starter? Mine had a #8 wire, connected to the solenoid by a common yellow crimp-on terminal, and cold soldered to the field coil connection. Of course it was severly burned because of its small size. I've tried a piece of #4 battery cable, but it doesn't want to bend in a small radius to meet the field terminal after it passes thru the square, rubber protector in the end of the starter case. I think an insulated flat copper bar may have been used. Can you describe how your solenoid is connected to the starter field coils?
Thanks [email protected]
