Tractor Talk Discussion Forum
1972 Ford 2000 clutch/PTO
Dick
01-13-2004 11:53:05
I have a 1972 Ford 2000. The gears shift OK, but the PTO will not engage with an implement attached. I have to shut off engine,engage pto and then start engine. Any suggestion? Not a live clutch.
RickB
01-13-2004 15:50:26
 Re: 1972 Ford 2000 clutch/PTO in reply to Dick, 01-13-2004 11:53:05
Sounds like you have an 8 speed and live PTO with a problem. Either the external clutch rod is in the wrong hole, the freeplay is too great, the PTO disc is stuck, the transmission disc is worn thin, or one or more of the pressure plate links are broken. I can't imagine any scenario where a transmission driven PTO would grind and not engage when the single disc clutch was disengaged and the transmission was able to be shifted. Can you feather the clutch and have the PTO engage?
