Tractor Talk Discussion Forum
alberta parts sources/44 massey harris
wye not
01-11-2004 17:30:53
Can anyone supply me with some parts places near edmonton ab. where i might find timing chain and gears for a 44 special with a 4 cyl. as well as other parts i may reqire.
Mark in AB
01-11-2004 20:13:05
 Re: alberta parts sources/44 massey harris in reply to wye not, 01-11-2004 17:30:53
Try the western producer classifieds under salvage. tons of wreckers listed probably have what you need.
Dan
01-11-2004 19:51:03
How about the big yard at Lamont? Dan in AB.
Alberta Mike
01-11-2004 19:12:15
There is an ad in this weeks Northern Alberta Bargain Finder for someone that is selling parts from a Massey 44. That ad has been run for some time now on and off.
marlowe
01-11-2004 18:51:33
i posted on the massey board. make sure you check out your dist. drive first if your sure your cam is turning then it's not your chain
Drill
01-11-2004 19:41:10
 Re: Re: alberta parts sources/44 massey harris in reply to marlowe , 01-11-2004 18:51:33
The Used Parts Ranch at Ponoka advertises that it has parts for most older tractors.
Drill
01-11-2004 19:45:58
 Re: Re: Re: alberta parts sources/44 massey harris in reply to Drill, 01-11-2004 19:41:10
You might also try McLoeds Tractor parts, there right in Edmonton.
