Tractor Talk Discussion Forum
m/f 235 starter
naz
01-11-2004 12:06:02
Still not starting.Replaced connections on the nuetral switch(crossed wires to test)checked and cleaned cables from battery,still nothing.Could it be a bad switch(on the dash) that shuts the power of from the pos.battery cable leading to the solenoid.The voltage is good on the battery side but drops down to about 5 or 6 volts on the other.It seems to freeze up in the cold,and does'nt want to move.anything I can do with it?Thanks for any help.
old
01-11-2004 12:20:41
 Re: m/f 235 starter in reply to naz, 01-11-2004 12:06:02
The easyest way to see if its the switch is to hot wire it, if that works its the switch or the wireing to the switch
Or...
01-11-2004 19:45:09
 Re: Re: m/f 235 starter in reply to old, 01-11-2004 12:20:41
...take a screwdriver and short across the starter solenoid, big post to small, ensure you are in "S" and Neutral. If it works then your starter switch or wiring could be bad. Next, pull the starter off and connect it to the battery with jumper cables, if it doesn't engage-suspect the solenoid or starter itself. Turn that radio down;-)
