Tractor Talk Discussion Forum
540 or 1000
clint
01-09-2004 21:03:14
I have a 9700 Ford. I will be looking soon for a used 15 ft. rotary cutter. Will it make any difference which rpm speed the cutter has? I've seen 15 footers advertised with 540 and 1000 gearboxes.
david val
01-10-2004 00:54:37
 Re: 540 or 1000 in reply to clint, 01-09-2004 21:03:14
the torqe loads on the 540 pto shaft are almost twice the load of the 1000 shaft for the same hp.
if the hp required by the work done is more then about 60 hp, go with the 1000.
david
