Tractor Talk Discussion Forum
Cleaning a serial number plate
Sheriffbob
01-07-2004 07:51:53
Hi guys, I need some advise. The serial number plate on my tractor is to the point where it is not readable. I am afriad to use anything that is abrasive on it for fear that it my destroy the information on the plate. Any go ideas what I could do or use? Thanks Bob
russ
01-07-2004 11:55:22
 Re: Cleaning a serial number plate in reply to Sheriffbob, 01-07-2004 07:51:53
take plain old soap and water and a soft sponge and take your time, alot of patience is the only way .the tractor loses about 20% of its value if you destoy the tag
rod
01-07-2004 08:50:39
try rubbing a lead pencil over it I have done this a few times and got the serial number to show up.
regards
rod
buickanddeere
01-07-2004 12:22:59
 Re: Re: Cleaning a serial number plate in reply to rod, 01-07-2004 08:50:39
Scrub with tooth paste and a soft bristle brush then the previously mentioned lead pencil trick..
chesterF/wisc.
01-07-2004 14:19:34
 Re: Re: Re: Cleaning a serial number plate in reply to buickanddeere, 01-07-2004 12:22:59
OK , A SERIAL NUMBER PLATE IS USUALY MADE OF STEEL OR BRASS AND IS LITHOGRAPHED WITH BLANK SPACES FOR DATA TO BE APPLIED LATER IN THE MANUFACTURING PROCESS BY STAMPING THE DATA IN THE SPACES WITH CASE HARDENDED DIES . I HAVE USED PAINT REMOVER WITH GOOD SUCESS, IT IS IMPORTANT TO WASH OFF THE PAINT REMOVER AFTER THE CLEANING WITH SOAP AND WATER. DO NOT USE PAINT REMOVER IF THE SERIAL NUMBER APPEARS TO BE A DECAL.
Slowpoke
01-07-2004 19:52:17
 Re: Re: Re: Re: Cleaning a serial number plate in reply to chesterF/wisc., 01-07-2004 14:19:34
And the lithography printing can be wiped out with a little 409 or other similar household cleaners. WD 40 works wonders to remove printed serial numbers, too. Like on my '60 Cub Lowboy.
