Tractor Talk Discussion Forum
power block questions???
70 plowboy
01-06-2004 23:04:54
NEED help ive got a J.D.70gas and ive come across a M.W. power block just the block nothing else Anyone know what all do i need other than pistons and rings do you use the origanal head or do i need something differnt ? what about a head gasket ??and finally were can i find pistons for it
buickanddeere
01-07-2004 04:35:11
 Re: power block questions??? in reply to 70 plowboy, 01-06-2004 23:04:54
Be wary of leaking "O" rings in the wet sleeves.After 43+ years, being disturbed by maching and hot tanking they can leak. Hinrichs at 815-499-6580 may have pistons. There are new "power blocks" being cast up to 7-1/2" dia bores. The name excapes me at the moment. Origional head bolts on. Flow is crummy until all fuel valves are installed with a nailhead back cut, three angle valve job, blended valve bowls and a cam from Roberts.
