Tractor Talk Discussion Forum
Farmall A Ringgear
Jim
01-02-2004 10:33:33
Does anyone know where I can get a Ringgear for a Farmall "A"?
Jim
Bob
01-02-2004 12:26:28
 Re: Farmall A Ringgear in reply to Jim , 01-02-2004 10:33:33
Your local CNH dealer???
Gary-Miss
01-02-2004 18:32:54
 Re: Re: Farmall A Ringgear in reply to Bob, 01-02-2004 12:26:28
If you are in a tight and desperate, you can heat your arter ring gear til it falls off, let the flywheel cool (as in cold), reverse the ring gear, rotate it 1/4 turn from its original position, reheat it black hot and drop it back on. The four cylinder, 4 cycle crank generally only wears bad in two places. DO NOT tap it back on with a hammer. If it doesn't fall on, it's not hot enough and you will stretch. Then, you have to get a new one or spot weld the old one to keep it from slipping. Good luck.
