Tractor Talk Discussion Forum
salt in hay
steve in wis
06-19-2007 07:13:17
Going to bale 4 acres of brome,timithy and alfafa mix, In some spots of the field theirs alot of clover that mixed in,The clover not drying real well,been spreading it out by hand to get it to dry,If some of this clover gets in the dry bales,will salting the bales help,or should i just take all those bales to the neighbors steers. Not going to get the clover dry enough before our rain. Thanks Sorry to hear about brothers barn Ia gary Thanks
iowa_tire_guy
06-19-2007 17:23:03
 Re: salt in hay in reply to steve in wis, 06-19-2007 07:13:17
Back in 1983 we PICed some wheat so we made hay of it. Most of it was big baled but we square baled some for barn feed. It sure went in nice but the next morning we could smell it starting to heat. So we torn it down and stacked it on it's sides with air spaces in between like only half as tight as normal. Dried out nice and made good hay.
1936
06-19-2007 16:54:48
Worked for a guy that square baled oats on the green side. Stacked in the barn on edge and spread rock salt on each layer. This was used to feed horses in the winter. Salt used to get the horses to eat it.
Leland
06-19-2007 13:10:13
Find a restruant supply place and buy a couple of 50 lb bags of table salt a little salt goes a long way but don't get to carried away I have had the wires rot off from to much salt .
dboll
06-19-2007 11:10:33
we bought rock salt in the 50# bags and spread it heavily between layers of bales, I think it helped, Dad was certain it helped. If you have room in the building scatter them and stack them later.
buickanddeere
06-19-2007 10:06:28
The addition of salt and it's effect on curring damp hay depends on who you ask. If it's going to work at all it takes a fair amount of salt to "pickle" anything. A table spoon full of salt on the top of each bale certainly isn't enough.
johndeereman
06-19-2007 09:19:32
salt does help hay cure if i were you id set them bales aside and check em every day for a while to see if they are heating up
Ken Macfarlane
06-20-2007 10:27:39
 Re: salt in hay in reply to johndeereman, 06-19-2007 09:19:32
Studies have shown salt does nothing for curing, but it certainly helps the taste. They will chomp down old mouldy bales with some salt on it.
