Tractor Talk Discussion Forum
power steering
mark
12-26-2003 15:16:23
have a 1966 ford 3000 with power steering. Power steering fluid started gushing out under the dash. Any ideas as to the cause and what the remedy might be.
Thanks.
Mark
Mark in AB
12-26-2003 17:29:59
 Re: power steering in reply to mark, 12-26-2003 15:16:23
hand metering unit is leaking, either a line or fitting failed on the unit if you are lucky, if not, the bolts holding the unit loosened and blew the oring seals out. If the unit loosened up, get a manual and follow it very closely to reseal.
