Tractor Talk Discussion Forum
Antifreeze Ph ???
Jerry (KS)
12-23-2003 11:59:08
How often are you suppose to check the Ph of antifreeze in a diesel tractor? Do you also put in any anticativation supplement to the antifreeze? And lastly, where do you find the litmus (sp) paper to check the Ph?
Ben in KY
12-23-2003 13:16:21
 Re: Antifreeze Ph ??? in reply to Jerry (KS), 12-23-2003 11:59:08
You should check the antifreeze in your diesel at least once a year and put in additives as required. Anti-cavitation additives are required in a diesel. Test strips should be available at any good auto parts place.
Tim in NB
12-23-2003 18:12:03
 Re: Re: Antifreeze Ph ??? in reply to Ben in KY, 12-23-2003 13:16:21
The test strips are easier to get at any heavy truck dealer.
Ray,IN
12-23-2003 20:39:59
 Re: Re: Re: Antifreeze Ph ??? in reply to Tim in NB, 12-23-2003 18:12:03
Any diesel engine should also use low silicate anti-freeze, and the additive(DCA-4)only if it has wet sleeves.
