Tractor Talk Discussion Forum
hydrolic top link grading blade
mudstuck
12-21-2003 15:52:07
do any of you fellas use a hyd. top link with your grading blade? we got a long farm lane to keep up and my blade does a lot of bouncing even at slow ground speeds. seems like it does more pogo stickin than gradin.
Richard Fazio
12-22-2003 05:48:02
 Re: hydrolic top link grading blade in reply to mudstuck, 12-21-2003 15:52:07
My blade would bounce around a lot also when I first started using it. I don't know if your doing it but, I found if I angle it about 45 degrees it stops. It also grades a smoother road when angled. I usually grade toward the center then back out to the sides. It comes out darn slick.
RWK in WI
12-22-2003 05:58:47
 Re: Re: hydrolic top link grading blade in reply to Richard Fazio, 12-22-2003 05:48:02
The hyd. top link makes it easy to adjust the front to back tilt of the blade and make the blade bite in more easily - top link extended - or slide over the material more easily - top link shortened-. To stop the bouncing it helps to add weight. I generally use 4 suitcase weights ( about 90# each ) on my 7' HD Arps blade behind my Ford 3000 ( about 40 HP ),
I hope this helps you.
John A.
12-21-2003 20:21:04
Mudstuck, I have thought about it but haven't done it. I do put 2, 100 lb suitcase wts on my blades frame work. It does stop the bouncing. Go slow, pick a time when soil moisture is good, after about 1/2 in rain. Works well. but, my best results happen after I roll the road with my ol 4000 lb road roller.
It would be very easy to over Hoss a light blade. Be careful.
Good Luck,
John A.
Butcher
12-21-2003 19:02:20
I have one on my 1750 Oliver. I would not be without it. Use it for gradeing, snowblowing, ect. Bought a cheap cylinder, built 2 nuckles for each end and pluged it into one of my remotes. I found you have to be a bit carefull when grading. To much tractor and to light of a blade can fold a blade in half or dig to he!! and back.
