Tractor Talk Discussion Forum
Tires for farmall c or super c
george
12-16-2003 19:31:54
If anyone can help, I have a farmall c or super c, not sure which, I bought at cheap and want like to restore it,it needs alot so I'll be asking fora lot of advise. First thing I want to take care of is the tires, so as to make it mobile, on one side it's a 12-36, and the rim says 11", this tire and rim are in great shape, the other tire is a 12.4-36, 11"rim, this tire is totaly shot and the rim is a little rusted at the hole for the stem, thinke it can be repaired, on hte tire I don't know which tire size to go with, someone mention goinh to another size all together, is there another rim size I can put on this model, if so how do I determine that, or should I stick with what I have on there, appricate any help. Thanks George
John in Md.
12-17-2003 14:30:35
 Re: Tires for farmall c or super c in reply to george, 12-16-2003 19:31:54
If serial number is above 100000 it's a Super C. I used to have a C back in the 60's and it had 9.5x36 Goodyears on it.
Brian Schmidt
12-17-2003 09:16:44
I have Titan 11.2X36 on both mine and I think they are the perfect size for it.
oleblu
12-17-2003 04:50:28
George, the tire marked 12-36 should be on a 12" wide rim, 36" diam. The 12.4X36 tire goes on a 11" wide rim. If the 12-36 does not require replacing, it should be matched with a 13.6X36. Clear as mud, huh? oleblu
Brian Schmidt
12-17-2003 09:20:12
 Re: Re: Tires for farmall c or super c in reply to oleblu, 12-17-2003 04:50:28
oleblu,
Do you know of any smoking deals on some 12.4X38 over your way?
I just bought a Farmall H and need a pair.
Cannot wait until spring time plowing to test her out!!
Brian Schmidt
oleblu
12-17-2003 15:21:43
 Re: Re: Re: Tires for farmall c or super c in reply to Brian Schmidt, 12-17-2003 09:20:12
Brian, there is a BRAND NEW pair mounted on NEW H rims in the back room at the store. Not sure why they haven't been picked up yet, but for a price..... ..anything is possable. LOL I'll check on a price for new ones and get back to you. Jim
Jim in michigan
12-16-2003 19:47:44
Tire size is 12x36 thats what I had on mine,, as for C or Super C,,if its after serial number 100000 its a Super C...Jim
