Tractor Talk Discussion Forum
Extra hydraulic for Deutz
jdj
12-15-2003 11:32:18
Hi,
Does anyone know if there is a possibility to add extra hydraulic control valves in Deutz 4006 ?
There is on outlet for single action cylinder now, but i want have few more and for double action cylinder. I think that i can take the input for extra valve from the current outlet but where should i put the return line ? Is there places ready for that or must i make new hole to the hydraulic tank.
Robert in W. Mi
12-15-2003 15:35:36
 Re: Extra hydraulic for Deutz in reply to jdj, 12-15-2003 11:32:18
To add valves (remotes) to your Deutz, you just buy another valve body, and "stack" it onto the one you already have. All you need is longer bolts to go through the whole thing.
Make sure the spl. flat O-rings are in place, in the recess' for them!
Robert
jdj
12-17-2003 11:57:49
 Re: Re: Extra hydraulic for Deutz in reply to Robert in W. Mi, 12-15-2003 15:35:36
Thanks, i've heard that possibility before. Now i thinked to place valves onto better place than original is. So it would need pressure incoming and return line using pipes from hydraulic system.
