Tractor Talk Discussion Forum
easy parts
drew
12-13-2003 07:08:44
What mid-size (12-30 h.p.)antique tractors are easiest to find affordable parts and implements for? Thanks
rustyfarmall
12-13-2003 13:30:29
 Re: easy parts in reply to drew, 12-13-2003 07:08:44
Log on to e-bay, do a search for whatever brand of tractor you might be considering, and go with the brand of tractor that you find the most parts for. You can also search for implements and other attachments.
Todd
12-13-2003 12:50:16
Case model VAC is a good small tractor (19 HP). Does anything a Ford 8N will with about half the cost. I also think they are more Driver friendly than the fords. Most Fords though will have wide front and the VAC was more common in Tricycle front end. Catagory 1 Hitch and pretty easy to find parts for. Really depends on what you are going to use it for..... ..
Ron
12-13-2003 08:46:40
JD "B" is very easy to get parts, AC's are very reasonable, and the parts are not at all hard to find..plows, etc. are still easy to find... Do you want a "Tractor", or a "LawnMower"...??
Rlach
12-13-2003 07:39:46
If antique means before 1952, then :
1 - Ford 8N/2N/9N, 2 - Fergies.
Rlach
